Data Import
Import text files, native data files and Touchstone format files.
Multiple selected files located in the same folder can be imported in a single import, but only a single custom data file can be imported at a time.
Data that was imported into POSTFEKO can be added to a graph in the same manner as other any result. The project browser contains an entry for each import under Imported files. Imports can be deleted from the project should they no longer be required.
Saving a project with imported results stores it as part of the POSTFEKO session file (.pfs) file.
