Learn to use Inspire Cast with our interactive
tutorials.
Training
Explore Altair's resources for training and support.
Tutorial: Core Component
See the difference in porosity of a solid model and the same model with a core.
Tutorial: Sleeve Component
Compare the solidification in a riser with that of risers with isothermal and exothermal sleeves.
Tutorial: Chiller Component
See how the two halves of a reflectionally symmetric part solidify when a chiller is added to one side.
Tutorial: Cooler Component
Observe how a cooler helps maintain a homogeneous temperature range throughout a mold, particularly in High Pressure Die Casting.
Tutorial: Gravity Casting
Run a simulation of a gravity casting adjusting different components to see the effects on the results.
