Traffic Settings
There are different approaches for modeling cell loads in ProMan.
If no explicit traffic is defined, the cell load used for interference calculations can be specified in terms of the assumed mean transmit power in downlink (in percent of the maximum available transmit power of the cell together with the definition of the assumed mean noise rise) and the power backoff for the cell assignment channel. These definitions can be specified either for all cells of the network or for each cell individually.
In case clutter maps are available for location dependent traffic definitions, cell loads can be determined based on traffic generated during static or Monte Carlo network simulations.
Cell Load Defined by User
If the traffic is defined independent of the location, a traffic map is not required because it is assumed that the traffic is homogeneously distributed over the complete prediction area.
Figure 1. The Edit project parameter dialog - Traffic tab.
The cell load used for interference calculations can be specified in terms of the assumed mean transmit power in downlink in percent of the maximum available transmit power of the cell.
Note: This value is only related to the power assigned for data transmission. The power specified for the pilot signals is not influenced. In case of OFDM air interface the cell load can either influence transmit power in downlink or the number of used subcarriers, depending on the settings.
For interference computation in uplink, an assumed mean noise rise, caused by active mobile stations, can be specified.
The default values for cell load, noise rise and power backoff can be defined in the upper section of the Edit project parameter dialog. In the lower part all transmitters of the current project are listed and the settings for each transmitter are displayed in the table. The text default indicates that a default values defined in the upper section of the dialog is used for the corresponding transmitter. If individual settings for a transmitter is to be defined, the transmitter has to be selected in the table and the check boxes and edit boxes at the bottom of the dialog can be used to define individual values for cell load, noise rise and power backoff.
Location Dependent Traffic Definitions
For the definition of location dependent traffic a traffic map is necessary.
Figure 2. Settings on the Traffic tab with speech settings.
Applications
Location dependent traffic requires the specification of at least one application. Reasonable applications are for example Voice Calls, Video Calls and WWW Downloads.
Figure 3. The Edit Application dialog.
Name
Description of application.
Position
Priority of the application during cell assignment. 0 means highest priority.
Color
Color of mobile stations generated for this application in display.
Definition of traffic / users
Either arrival rate in 1/sec/m² and hold time in sec or traffic in Erlang/m² can be defined.
Activity (occupation of resources over time)
Activity of users using this application (occupation of network resources over time) in %.
Transmission modes
At least one transmission mode must be assigned to each application. If an application is selected with the mouse, the assigned transmission modes are displayed in the upper-right part of the Edit project parameter dialog. If another application is selected by the user, the display of the transmission modes is refreshed automatically. Transmission modes can be added or removed with the corresponding buttons. The parameter Position specifies again the priority (0 means highest priority) with which the transmission mode is considered during cell assignment.
Clutter classes
Clutter classes contained in the database of the project which are assigned to the selected application. At least one clutter class is required to generate traffic for the defined application. If another application is selected by you, the display of the clutter classes is refreshed automatically. Clutter classes can be added or removed with the buttons in the lower-left section.
Traffic definition
When a clutter class is selected with the mouse the traffic values are displayed in the lower-right area. You can modify the values and thus assign them to the selected clutter class. Depending on the traffic mode specified for the current application, either two values (arrival rate in 1/sec/m² and hold time in sec) or one value (traffic in Erlang/m²) must be defined. The unit for the area definition (either m² or km²) can be modified with the drop-down list at the top of the dialog.
