Computation
The antenna pattern is automatically calculated by the multiple antenna scenario configuration (MASC) module once antenna patterns are added.
If the main dialog of the MASC settings is confirmed with OK, the computation starts.
Once the computation is done, the result is displayed.
Note: Depending on the scenario and computation mode, the calculation could take some time
