MASC Module
MASC (multiple antenna scenario configuration) module allows for realistic antenna patterns to be generated using superpositioning of multiple antenna that radiates the same signal. The module also considers the local environment (for example, masts, arms, walls, tubes, and sub-arms) in the solution.
