Specifying the Output Folder for the Prediction Results
Specify the folder for the prediction results to be computed using the multi-wall model (COST 231).
- Click the Propagation tab.
Specify the output folder for the results to be computed using the multi-wall model (COST 231).
- Under Output Directory / Basic Filename for Propagation Results, in the Directory field, change the default PropName to Prop01_MW.
![](../../../../images/winprop/getting_started_guide/example1/dialog_edit_project_parameters_propagation_tab.png)
Figure 1. The Edit Project Parameters dialog - Propagation tab.
