Troubleshooting
Addendum Surface Issues
- No addendum surface is created.
- There are missing surfaces and a partial addendum is created. Red indicates locations where the addendum surface failed to propagate.
- There aren't enough ribs.
Step 1: Fix Overlapping Ribs
Overlapping ribs is the most common issue, so we suggest starting off by fixing them manually.
Step 2: Delete Excess Ribs
Check for ribs that are too close together or lie on the same plane, and then manually delete excess ribs.
- Adjust the view as necessary to locate ribs that are too close together or lie on the same plane.
Delete ribs as necessary to smoothen the flow.
Step 3: Add Ribs
You can add ribs automatically and manually. Once you've added ribs, you can edit them to adjust the addendum.
Step 3A: Add Ribs at T-Intersections
Figure 5. Issue: Not Enough Ribs Created with Default Auto Create Rib Location Option
Step 3B: Add Ribs at All Vertices
Still not enough ribs were created automatically when you selected T-intersection vertices.
Step 3C: Restore Missing Ribs at Discontinuity Vertices
Check for missing ribs at discontinuity vertices and add ribs there.
- Adjust the view to locate discontinuity vertices where there are missing ribs.
- Hold down Alt while hovering over an addendum start edge, looking for green dots (discontinuity vertices) where there are missing ribs, and click these green dots to add ribs there.
Step 3D: Add Ribs at Custom Locations
You can add ribs at custom locations (for example, at long stretches without ribs or at corners to help the surface make a turn).
| To | Do this | Notes |
| Create a copy of a rib |
| Add new ribs |
| Copy some parameters of a source rib to target ribs |
The following parameters are passed on:
See Rib Options for parameter definitions. |
Figure 6. Issue 1: Long Stretch Without Ribs
Figure 7. Remedy 1: Add Ribs at Custom Locations to Build Addendum Surfaces All Around
Figure 8. Issue 2: Addendum Wall Doesn't Follow the Part
Edge
Figure 9. Resolution 2: First Add Ribs at Corners To Help Addendum
Surface Turn Properly
Figure 10. Resolution: Then Add Adjacent Ribs to Align the Addendum
to the Part EdgeStep 3E: Relax the Tangency to Propagate the Addendum
"Apply Smoothing" Deletes Some Surfaces
Condition
When I select Apply Smoothing, some addendum surfaces are deleted, and the addendum is displayed in red.
Cause 1
The addendum doesn't completely intersect the binder.
Remedy 1
- Deselect Apply Smoothing to go back to rib editing mode.
- Modify the ribs so that the addendum completely intersects the binder at the locations where the surface got deleted.
Cause 2
Remedy 2A: Fix Overlapping Ribs
Remedy 2B: Delete Excess Ribs
Cause 3
The Smoothing distance between the ribs is too large. Large areas are smoothened, causing overlapping ribs.
Remedy 3A
