Collect user input that is used in the script to operate.
Similar to the application environment variable, script variables are defined on the
task level and are therefore local. Their purpose is to collect user input which is
used in the script to operate. For example, the script is creating a parametrized
cuboid. The script needs the input of the dimensions from you. The script has the
data names defined as depth1, height1 and
width1.
In Pulse, the data names are defined under the user
properties of each task together with the GUI description. The author can define
what name will be displayed to you as well as what type of input is required, such
as text, numbers, file selection and checkboxes. Figure 1.
At the run time of the task the GUI will be generated allowing you to input the
requested information: Figure 2.
