Define parameters and execute an analysis to understand filling, packing, cooling or warpage events during molding.
Generate results for individual or combined events.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
Run an injection molding analysis to minimize defects and prevent manufacturing
problems.
Process Parameters
Define the filling, packing, cooling and machine parameters as required for the molding process. Default units shown are MKS (m kg N s).
Run Options
Choose whether to run jobs in sequence or in parallel.
Run Analysis
Define parameters and execute an analysis to understand filling, packing, cooling or warpage events during molding. Generate results for individual or combined events.
Use Advanced Meshing with SimLab
When running an analysis, automatically export your model and perform advanced meshing in SimLab.
Add Fiber Orientation Results
Select Add Fibers when running a detailed filling analysis to produce results that include fiber orientation tensors.
Animate and Record Results
Use the Animation Toolbar that appears at the bottom of the modeling window to animate and record results.
Run Status
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past runs, you need to view the run history.
Run History
View, sort, open, and delete past runs for the current and previous models.
