Setting up Bearing Reference Surfaces
Use the BRS tool to select bearing reference surfaces.
![](../../../images/figures/extrude/BRS_bearing_region.png)
![](../../../images/figures/extrude/BRS_choke.png)
For complex models, meshing the bearing with choke and relief is a tedious process, and most of the time auto-mesh will fail to mesh it. As an alternative, HyperXtrude solver has an option to handle the choke and relief using the bearing reference surfaces on the die geometry.
![](../../../images/figures/extrude/BRS_bearing_ref_surfaces.png)
Solution methodology:
Extract the bearing reference surfaces from the die geometry.
Mesh the bearing solid using drag mesh with no choke/relief.
Use the 2D mesh of the reference surfaces to determine the choke angle and estimate the friction.
Creating Bearing Reference Surfaces
