/TABLE/1
Block Format Keyword Defines a table with up to four dimensions using functions and/or data points.
| /TABLE/1/table_ID | |||||||||
| table_title | |||||||||
| dimension | |||||||||
| X1 | Y1 | ||||||||
| etc | etc | ||||||||
| Xn | Yn | ||||||||
| fct_ID1 | A1 | Scale_y1 | |||||||
| etc | etc | etc | |||||||
| fct_IDn | An | Scale_yn | |||||||
| fct_ID1 | A1 | B1 | Scale_y1 | ||||||
| etc | etc | etc | etc | ||||||
| fct_IDn | An | Bn | Scale_yn | ||||||
| fct_ID1 | A1 | B1 | C1 | Scale_y1 | |||||
| etc | etc | etc | etc | etc | |||||
| fct_IDn | An | Bn | Cn | Scale_yn | |||||
| table_ID | Table
identifier. (Integer, maximum 10 digits) |
| table_title | Table
title. (Character, maximum 100 characters) |
| dimension | Total number of
entries. (Integer ≤ 4) |
| Xi - Xn | ith
abscissa value, where 1 ≤ i ≤ n. (Real) |
| Yi - Yn | ith
ordinate value, where 1 ≤ i ≤ n. (Real) |
| fct_IDi | ith
function identifier, where 1 ≤ i ≤ n. (Real) |
| Ai | ith A
value, corresponding to
fct_IDi,
where 1 ≤ i ≤ n. Default = 0 (Real) |
| Bi | ith B
fct_IDi,
| Ci | ith C
fct_IDi,
| Scale_yi | Scale factor for the
ordinate of the ith
function, where 1 ≤ i ≤ n. Default = 1 (Real) |
- X
- Plastic strain
- Y
- Stress
For dimension=3, yield stress depending on plastic strain, strain rate and temperature could be considered.
- X
- Plastic strain
- Y
- Stress
- Ai
- Strain rate
- Bi
- Temperature
/TABLE/1/1007
table type 1 with dimension 1 (same like /FUNCT)
#DIMENSION
1
# X T
0 0
0.1 210
0.2 220
0.3 225
0.5 228
/TABLE/1/1008
table type 1 with dimension 3
#DIMENSION
3
# FCT_ID Y Z
4173 1 300 1
4174 5 300 1.2
/FUNCT/4173
New FUNCT 4713
# X Y
0 0
0.1 210
0.2 220
0.3 225
0.5 228
/FUNCT/4174
New FUNCT 4714
# X Y
0 0
0.1 210
0.2 220
0.3 225
0.5 228
#enddata
- The input of dimension=1 is similar to the input of a function /FUNCT.
- A function and a table cannot share the same identifier.
- Each function which is referenced can be defined through /FUNCT or /TABLE/1/table_ID and dimension=1.
- The abscissa of associated functions is considered as the first entry. Next, the input entries A, B and C are considered as second, third and fourth entries.
- A function must be associated to each possible combination of entries A, B, and C.
- The cards associating functions to the combinations of entries may be entered in an arbitrary order.
- Each function may have unique spacing and arbitrary number of points in their definition.
- The functions are completed up to the total number of abscissa values among all functions which are referenced into the table: each function is linearly extrapolated with a slope defined by the two first (resp. two last) points of the function. It is linearly interpolated between two consecutive points of the function.
