/MOVE_FUNCT
Block Format Keyword This describes the function scale and shift.
| /MOVE_FUNCT/fct_ID | |||||||||
| move_funct_title | |||||||||
| Ascalex | Fscaley | Ashiftx | Fshifty | ||||||
| fct_ID | Function
| move_funct_title | Move function
| Ascalex | Abscissa scale
factor Default = 1.0 (Real) |
| Fscaley | Ordinate scale
| Ashiftx | Abscissa shift
value Default = 0.0 (Real) |
| Fshifty | Ordinate shift
- The function linked to this option
is scaled first and shifted afterwards, as follows:
(1) (2) with and are values from function fct_ID.
- It is recommended that the final list of abscissa value in the function be increased (which means the abscissa value in the function needs to be greater than the previous abscissa value).
