/RWALL/THERM
Block Format Keyword Describes the ALE rigid wall.
/RWALL/THERM/wall_ID
wall_title
Format only if node_ID = 0
node_ID Slide grnd_ID1 grnd_ID2
Dsearch fric ϕ
XM YM ZM
XM1 YM1 ZM1
fct_IDT   FscaleT R
Format only if node_ID > 0
Dsearch fric ϕ
Mass VX0 VY0 VZ0
XM1 YM1 ZM1
fct_IDT   FscaleT R
wall_ID Rigid wall identifier.
(Integer, maximum 10 digits)
wall_title Rigid wall title.
node_ID Node identifier of the moving rigid wall.
(Integer)
Slide Sliding flag.
= 0
Sliding
= 1
Tied
= 2
Sliding with friction
(Integer)
grnd_ID1 Node group defining secondary nodes to be added to the rigid wall.
(Integer)
grnd_ID2 Node group defining secondary nodes to be deleted from the rigid wall.
(Integer)
Dsearch Distance for secondary search.
(Real)
[ m ]
fric Friction.
(Real)
ϕ Diameter.
(Real)
[ m ]
XM X coordinate of M, if node_ID = 0.
(Real)
[ m ]
YM Y coordinate of M, if node_ID = 0
(Real)
[ m ]
ZM Z coordinate of M, if node_ID = 0.
(Real)
[ m ]
Mass Mass of the rigid wall, if node_ID > 0.
(Real)
[ kg ]
VX0 Initial velocity in X direction, if node_ID > 0.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
VY0 Initial velocity in Y direction, if node_ID > 0.
(Real)
VZ0 Initial velocity in Z direction, if node_ID > 0.
(Real)
XM1 X coordinate of M1.
(Real)
[ m ]
YM1 Y coordinate of M1.
(Real)
[ m ]
ZM1 Z coordinate of M1.
(Real)
[ m ]
fct_IDT Wall temperature function.
(Integer)
FscaleT Wall temperature scale factor.
(Real)
[ K ]
R Thermal resistance R = d / K.
d
Length
K
Thermal conductivity
(Real)
[ m ⋅ K W ]
  1. Only plane type of rigid wall is available for /RWALL/THERM. Coordinate of M and M1 is used to define the normal of plane.
  2. The first input format used to define the rigid wall is the coordinates of one point M or a node identifier node_ID in case of moving rigid wall.
  3. Next input format is the coordinate of a point M1.
  4. The secondary nodes can be defined as a list of nodes and/or as the nodes initially at a distance less than Dsearch from the wall.
