/EBCS/INLET
Block Format Keyword Define the inlet elementary boundary condition used with /MAT/LAW151.
/EBCS/INLET/form/ebcs_ID/unit_ID
ebcs_title
surf_ID vel_flag
fct_IDvx Fscalevx fct_IDvy Fscalevy fct_IDvz Fscalevz
fct_IDvf1 Fscalevf1 fct_IDrho1 Fscalerho1 fct_IDp_e1 Fscalep_e1
etc etc etc etc etc etc
fct_IDvfN FscalevfN fct_IDrhoN FscalerhoN fct_IDp_eN Fscalep_eN
form Formulation of INLET boundary condition.
VE
Input density and energy using fct_IDp_e and Fscalep_e
VP
Input density and pressure using fct_IDp_e and Fscalep_e
ebcs_ID Elementary boundary condition identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier
ebcs_title Elementary boundary condition title.
surf_ID Surface identifier.
(Integer)
vel_flag Velocity type of INLET boundary.
=0 (Default)
Input normal velocity in fct_IDvx and Fscalevx.
=1
Input 3 components of the velocity.
(Integer)
fct_IDvx If vel_flag =0, function f V X ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGwbGaamiwaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B53@ identifier is the normal velocity.
If vel_flag =1, function f V X ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGwbGaamiwaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B53@ identifier for X velocity.
=-1
Velocity is interpolated, based other defined inputs.
=0
V X = F s c a l e V X MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaWGybaabeaakiabg2da9iaadAeacaWGZbGaam4yaiaadgga caWGSbGaamyzamaaBaaaleaacaWGwbGaamiwaaqabaaaaa@403B@ .
= n
V X = F s c a l e V X ⋅ f V X ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaWGybaabeaakiabg2da9iaadAeacaWGZbGaam4yaiaadgga caWGSbGaamyzamaaBaaaleaacaWGwbGaamiwaaqabaGccqGHflY1ci GGMbWaaSbaaSqaaiaadAfacaWGybaabeaakmaabmaabaGaamiDaaGa ayjkaiaawMcaaaaa@47EB@ .
(Integer)
Fscalevx If vel_flag =0, normal velocity scale factor
If vel_flag =1, X velocity scale factor
Default = 0.0 (Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
fct_IDvy Function f V Y ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGwbGaamiwaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B53@ identifier for Y velocity.
=-1
=0
V Y = F s c a l e V Y MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaWGybaabeaakiabg2da9iaadAeacaWGZbGaam4yaiaadgga caWGSbGaamyzamaaBaaaleaacaWGwbGaamiwaaqabaaaaa@403B@ .
= n
V Y = F s c a l e V Y ⋅ f V Y ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaWGybaabeaakiabg2da9iaadAeacaWGZbGaam4yaiaadgga caWGSbGaamyzamaaBaaaleaacaWGwbGaamiwaaqabaGccqGHflY1ci GGMbWaaSbaaSqaaiaadAfacaWGybaabeaakmaabmaabaGaamiDaaGa ayjkaiaawMcaaaaa@47EB@ .
(Integer)
Fscalevy Y velocity scale factor
Default = 0 (Real)
fct_IDvz Function f V Z ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGwbGaamiwaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B53@ identifier for Z velocity.
=-1
=0
V Z = F s c a l e V Z MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaWGybaabeaakiabg2da9iaadAeacaWGZbGaam4yaiaadgga caWGSbGaamyzamaaBaaaleaacaWGwbGaamiwaaqabaaaaa@403B@ .
= n
V Z = F s c a l e V Z ⋅ f V Z ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaWGybaabeaakiabg2da9iaadAeacaWGZbGaam4yaiaadgga caWGSbGaamyzamaaBaaaleaacaWGwbGaamiwaaqabaGccqGHflY1ci GGMbWaaSbaaSqaaiaadAfacaWGybaabeaakmaabmaabaGaamiDaaGa ayjkaiaawMcaaaaa@47EB@ .
(Integer)
Fscalevz Z velocity scale factor.
Default = 0 (Real)
Repeat the following lines for each /MAT/LAW151 submaterial 1 through N
fct_IDvf1 Function f v f ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGwbGaamiwaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B53@ identifier for volume fraction.
=-1
Volume fraction is interpolated, based other defined inputs.
=0
V o l u m e F r a c t i o n = F s c a l e v f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiaad+ gacaWGSbGaamyDaiaad2gacaWGLbGaamOraiaadkhacaWGHbGaam4y aiaadshacaWGPbGaam4Baiaad6gacqGH9aqpcaWGgbGaam4Caiaado gacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamODaiaadAgaaeqaaaaa @4B6F@ .
= n
V o l u m e f r a c t i o n = F s c a l e v f ⋅ f v f ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiaad+ gacaWGSbGaamyDaiaad2gacaWGLbGaamOzaiaadkhacaWGHbGaam4y aiaadshacaWGPbGaam4Baiaad6gacqGH9aqpcaWGgbGaam4Caiaado gacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamODaiaadAgaaeqaaOGa eyyXICTaciOzamaaBaaaleaacaWG2bGaamOzaaqabaGcdaqadaqaai aadshaaiaawIcacaGLPaaaaaa@536C@ .
(Integer)
Fscalevf1 Alpha scale factor.
Default = 0 (Real)
fct_IDrho1 Function f r h o ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGwbGaamiwaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B53@ identifier for density.
=-1
Density is interpolated, based other defined inputs.
=0
ρ = F s c a l e r h o MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdiNaey ypa0JaamOraiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqa aiaadkhacaWGObGaam4Baaqabaaaaa@412D@ .
= n
ρ = F s c a l e r h o ⋅ f r h o ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdiNaey ypa0JaamOraiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqa aiaadkhacaWGObGaam4BaaqabaGccqGHflY1ciGGMbWaaSbaaSqaai aadkhacaWGObGaam4BaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@49FD@ .
(Integer)
Fscalerho1 Density scale factor.
Default = 0 (Real)
[ kg m 3 ]
fct_IDp_e1 If form =VE, function identifier for energy, f p _ e ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGWbGaai4xaiaadwgaaeqaaOWaaeWaaeaacaWG0baacaGL OaGaayzkaaaaaa@3C5D@ .
If form =VP, function identifier for pressure f p _ e ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGWbGaai4xaiaadwgaaeqaaOWaaeWaaeaacaWG0baacaGL OaGaayzkaaaaaa@3C5D@ .
=-1
P or E is interpolated, based other defined inputs.
=0
P  or  E = F s c a l e p _ e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaabc cacaqGVbGaaeOCaiaabccacaWGfbGaeyypa0JaamOraiaadohacaWG JbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaadchacaGGFbGaamyzaa qabaaaaa@4423@ .
= n
P  or  E = F s c a l e p _ e ⋅ f p _ e ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaabc cacaqGVbGaaeOCaiaabccacaWGfbGaeyypa0JaamOraiaadohacaWG JbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaadchacaGGFbGaamyzaa qabaGccqGHflY1ciGGMbWaaSbaaSqaaiaadchacaGGFbGaamyzaaqa baGcdaqadaqaaiaadshaaiaawIcacaGLPaaaaaa@4CDD@ .
(Integer)
Fscalep_e1 If form =VE, energy scale factor.
If form =VP, pressure scale factor.
Default = 0 (Real)
  1. Input is general, no prior assumptions are enforced! You must verify that the elementary boundaries are consistent with general assumptions of ALE (equation closure).
  2. Density, pressure, energy are imposed according to a scale factor and a time function. If the function number is 0, the scale factor input is used as a contstant imposed density, pressure or energy.
  3. The INLET boundary condition is only compatible with /MAT/LAW151. Inlet functions for volume fraction, density and pressure (or energy depending on the formulation VP or VE) must be provided for every phase present in the /MAT/LAW151 card.
  4. If the function ID that defines the volume fraction, velocity, density, pressure or energy is equal to -1, the corresponding physical quantity is interpolated from the inside of the domain (zeros normal derivative).
