/PROP/TYPE14 (FLUID)
Block Format Keyword Describes the general fluid property set.
| /PROP/TYPE14/prop_ID or /PROP/FLUID/prop_ID | |||||||||
| prop_title | |||||||||
| Blank Format | |||||||||
| qa | qb | h | |||||||
| prop_ID | Property
| prop_title | Property
| qa | Quadratic bulk
viscosity Default = 10-20 (Real) |
| qb | Linear bulk
| h | Hourglass viscosity
coefficient Default = 0.10 (Real) |
Example (Fluid)
#RADIOSS STARTER
/PROP/FLUID/2
FLUID (unit kg_m_s) data from Example 39 - Biomedical Valve
# blank card
# q_a q_b h
1E-20 1E-20 .1
#ENDDATA
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- The qa and qb default values are equal to 1.10 and 0.05 in non-CFD versions.
