/IMPTEMP
Block Format Keyword Defines imposed temperatures on a group of nodes.
/IMPTEMP/imptemp_ID/unit_ID
imptemp_title
fct_IDT sens_ID grnd_ID
Ascalex FscaleY Tstart Tstop
imptemp_ID Imposed temperature block identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
imptemp_title Imposed temperature block title.
fct_IDT Time function identifier.
(Integer)
sens_ID Sensor identifier.
≠ 0
The imposed temperature is applied after sensor activation. The time function is shifted in time.
(Integer)
grnd_ID Node group to which the imposed temperature is applied.
(Integer)
Ascalex Abscissa (time) scale factor for fct_IDT.
Default = 1.0 (Real)
[ s ]
Fscaley Ordinate (temperature) scale factor for fct_IDT.
[ K ]
Tstart Start time.
(Real)
[ s ]
Tstop Stop time.
Default = 1030 (Real)
[ s ]
  1. /IMPTEMP is not compatible with ALE applications (/ALE, /EULER). Imposed temperature will not be applied to ALE nodes or ALE elements.
