/GRSPRI/GEN_INCR
Block Format Keyword Generates a group of springs by listing the first and last spring IDs in the range with a user-defined increment value.
| /GRSPRI/GEN_INCR/grspri_ID/unit_ID | |||||||||
| grspri_title | |||||||||
| first_ID | last_ID | Incr | |||||||
| grspri_ID | Spring group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grspri_title | Spring group
| first_ID | First spring element
identifier in the list. (Integer) |
| last_ID | Last spring element
| Incr | Increment value of the
list generation from first_ID to
last_ID. Default = 1 (Integer) |
- The group includes first_ID, first_ID+Incr, first_ID+2*Incr, first_ID+3*Incr, … continuing through last_ID.
- Multiple first_ID, last_ID, and Incr lines can be defined in one block.
