/FAIL/XFEM_FLD (Obsolete)
Block Format Keyword Describes a XFEM (eXtended Finite Element Method) failure model.
| /FAIL/XFEM_FLD/mat_ID/unit_ID | |||||||||
| fct_ID | Ifail_sh | ||||||||
Optional Line
| fail_ID | |||||||||
| mat_ID | Material
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| fct_ID | Function
identifier (Integer) |
| Ifail_sh | Shell failure flag
(Integer) |
| fail_ID | (Optional) Failure
criteria identifier 2 (Integer, maximum 10 digits) |
- This failure model is
available for Shell only.
Figure 1. - The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
