/BOX/CYLIN
Block Format Keyword Describes a cylinder box for entities selection.
/BOX/CYLIN/box_ID/unit_ID
box_title
N1 N2   Diameter
Xp1 Yp1 Zp1
Xp2 Yp2 Zp2
box_ID Box identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
box_title Box title.
N1 Node identifier.
N2 Node identifier.
Diameter Diameter of cylinder.
(Real)
Xp1 X coordinate of point P1.
(Real)
Yp1 Y coordinate of point P1.
(Real)
Zp1 Z coordinate of point P1.
(Real)
Xp2 X coordinate of point P2.
(Real)
Yp2 Y coordinate of point P2.
(Real)
Zp2 Z coordinate of point P2.
(Real)
The pairs of nodes N1 and N2, or the pairs of points P1 and P2, are used to define the axis of the finite cylinder.
box_cyl
  1. A box (CYLIN) defined above is used for:
