Exercise 3: Run Your Simulation with Usersubs
In this exercise, you will run the simulation with the usersubs you implemented in Exercise 2: Add User Subroutines and compare the results to those from your initial test in the Exercise 1 step Run the Model.
Run the Model
In this step you will run the model with implemented usersubs.
Use HyperGraph to Plot the Displacement Magnitudes
In this step you will use HyperGraph and the outputs from both simulations to compare the displacement magnitude of the piston.
Use HyperView to Compare Flexbody Stresses
In this step you will use HyperView to compare the stresses and deformations on the flexbody.
