Exercise 2: Add User Subroutines
In this step, you will add Python user subroutines to the MotionView model.
py_
” must be added to the beginning. For example,
“py_sysfnc (…
” would be the correct usage of SYSFNC in Python. When defining a usersub function in Python, the name of the function and the inputs must match those
outlined in the MotionSolve online help pages exactly. When
accessing model data in Python through a function such as
SYSFNC, use the exact property name in quotations as the “id”
input. Model properties that are passed into Python in the
function definition can be accessed throughout the script, and do not need additional
defining to use. An example of these syntax rules being used is shown below:
def REQSUB(id, time, par, npar, iflag):
[A, errflg] = py_sysfnc(“DX”,[par[0],par[1]])
return A
Use SPLINE_READ to Replace the Curve Entity
In this step you will implement the SPLINE_READ subroutine.
Write the Python script:
- Open a new Python file.
Define a function with the name SPLINE_READ using
“def SPLINE_READ():"
, and give the inputs and outputsid, file_name
, andblock_name
Import the Python CSV package by
including
import csv
after the function definition. -
Open pressure_curve.csv in the function, and read the file
to your Python script as a variable.
Use the function
“variable = open(‘pressure_curve.csv’,’r’)”
Define a new variable to change the format of this variable. Use
csv.reader()
to read your variable file. -
Define an empty list,
“L”
, to store the pressure_curve data values. Iterate through the list using“for item in curv:”
. Append each item as a separate list value with“L.append(item)”
Remove the headers from the csv file by redefining the list from the second
value till the end of the list. This can be done with
“L = L[1:]”.
- Define a counter variable to be used later.
Define two lists that are half the length of
“L”
, and set them equal to zero.-
Use
“x = 16*[0.0]”
twice; once with the x value and once with the y value.
Use
- Create a while loop dependent on your counter variable being less than the length of your list, minus one.
In each iteration of the loop, define your x and y data values for the index
“i”
as a floating value of each half of your“L”
data sets. This should look like“x[i] = float(L[i][0])” and “y[i] = float(L[i][1])”
. Increase your counter variable by 1. -
Define a z variable with a floating value of 0.0, and close the csv file.
Note: Defining a z variable is necessary, as the next function you will use requires an x, y, and z variable.
Use the put_spline
MotionSolve function, and return the
“id”
, as well as the lists containing the first and second column of values and the z variable. This should be done with“errflg = py_put_spline(id,x,y,z)”
followed by“return errflg”
Save the file to your <working directory> as
nonlin_spline.py.
Your script should resemble the following example:
def SPLINE_READ(id, file_name, block_name): import csv ifile= open('pressure_curve.csv','r') ## opens data file as readable variable curv = csv.reader(ifile) ## reads csv data, stores as useable var. L = [] ## creates empty list for item in curv: L.append(item) ## separates file values into list L = L[1:] ## removes block names from list i=0 ## creates counter x = 16*[0.0] y = 16*[0.0] ## splits list into x and y lists while i < (len(L)-1): x[i] = float(L[i][0]) ## changes values from str to float y[i] = float(L[i][1]) i+=1 ## counter increment z = 0.0 ## defines z value ifile.close() ## closes data file errflg = py_put_spline(id,x,y,z) ## var to create MotionSolve spline return errflg ## returns var
Implement the Python script:
- In MotionView, click the (Curve) button.
- Locate the Force_Pressure curve in the Project Browser.
- From the Properties tab, check the box marked User-defined.
- From the Attributes tab, make sure Linear extrapolation is checked.
- Click on the User-Defined tab, and use the (File browser) to select the pressure_curve.csv file.
- Change the Function Type in the drop-down menu from DLL to Python, and ensure the function name is SPLINE_READ. You do not need to enter anything for the Block name, as it is not needed in this tutorial.
Check the box marked Use local file and function
name. Use the
(File browser) to locate and select the
nonlin_spline.py file.
Use REQSUB to Request an Output
In this step, you will use the REQSUB user-subroutine to return values of the magnitude of displacement for the piston.
Create a new Python file and define a function
named REQSUB with the appropriate inputs and outputs.
This is the syntax:
“def REQSUB(id, time, par, npar, iflag)”
Use the sysfnc utility to implement the
“DM” (displacement magnitude) function on the first and
second input parameters, and define a variable and an error flag by writing
“[D, errflg] = py_sysfnc(“DM”,[par[0],par[1]])”
Return a list of eight values, where the second value is your variable, and the
rest are equal to 0.
This will be your result variable, and should look like
“result = [0,D,0,0,0,0,0,0]”
Save this file to your <working directory> as
req_nonlin.py.
def REQSUB(id, time, par, npar, iflag): [D, errflg] = py_sysfnc("DM",[par[0],par[1]]) ## sets "D" as piston displacement mag result = [0,D,0,0,0,0,0,0] ## lists results for output return return result ## sends list with results to motionsolve as output
Implement the Python script.
- In MotionView, click on the (Outputs) panel.
- Locate the Output_Conrod_Length in the Project Browser.
- From the Outputs panel, from the drop-down menu select User defined.
- Click in the text field labeled Output, and then click on the button to open the Expression Builder. In the text field, add two sets of curly brackets (“{},{}”).
- From the Joints folder, click idstring. Click inside the first set of brackets and click Add to insert j_0.i.idstring.
Click inside the second set of brackets and add the next expression,
j_1.i.idstring.
- Click OK.
- Check the Use local file and function name box, and select Python from the Function Type drop-down menu.
Use the (Local File) file browser to locate and
select the req_nonlin.py script, and make sure the
Function name text field reads REQSUB.
Use GFOSUB to Replace the Force Entity
In this step, you will replace the Force Entity with a user defined Python script using GFOSUB.
Define the function GFOSUB by typing
“def GFOSUB(id, time, par, npar, dflag, iflag):”
Import
"pi"
from the Python“math”
library using“from math import pi”
. - Use the “AZ” function for angle in the z direction with the sysfnc command, to save it as a variable. To do this, type “[A, errflg] = py_sysfnc(“AZ”,[par[1],par[2]])”.
Change the variable defined in Step 4 to degrees. As the
model extends from the origin into the negative y direction, you will need to
multiply by -1.
Note: The method used in this tutorial is.
“B = ((-1)*A*180)/pi”
Define another variable using the “akispl” utility, which
interpolates the force values from the curve. You will need input arguments of
your angle
“B”
, zero to specify a two dimensional curve, and zero for the curve input and the order.Note: This line is written as“[C, errflg] = py_akispl(B,0,par[0],0)”
Return a list three elements long, where the second element is the variable
defined with the Akima interpolation function. The data from interpolation is
stored in the first column, so use
“return [0,C[0],0]”
gfo_nonlin.py.
def GFOSUB(id, time, par, npar, dflag, iflag): from math import pi [A, errflg] = py_sysfnc("AZ",[par[1],par[2]]) ## retreives conrod angle B = ((-1)*A*180)/pi ## converts radians to degrees [C, errflg] = py_akispl(B,0,par[0],0) ## interpolates data to fit curve return [0,C[0],0] ## returns C data as force values
- In MotionView, click the (Force) icon.
- Locate the Force_Gas_Pressure force in the Project Browser.
From the Connectivity tab, check the User-defined
properties box.
From the User-Defined tab, edit the Force value with the
Expression Builder to include the curve
idstring, the ground marker idstring, and the crank marker
idstring.
- Click OK.
Use to select
gfo_nonlin.py from your <working
directory>.
Remember: Make sure the Function name is set to GFOSUB.
Use MOTSUB to Define a Motion
In this step you will use the MOTSUB user subroutine to define a motion.
Define the MOTSUB function, including the required inputs.
The correct syntax for this is
“def MOTSUB(id, time, par, npar, iord, iflag):”
The MOTSUB user subroutine requires a function or
expression, and its first and second order derivatives. Create conditional
statements using the function order variable
“iord”
to define the function and its first and second derivatives with“if iord==0:”, “elif iord==1:”
and“else:”
The function and its derivatives should be defined with the same variable name.
The function used in this tutorial is
“A = 10.0461*time”
. This makes the first derivative equal to“A = 10.0461”
, and the second derivative equal to“A = 0.0”
- Return the function variable with “return A”.
mot_nonlin.py.
Your script should look like the following example:
def MOTSUB(id, time, par, npar, iord, iflag): if iord==0: ## function A = 10.0461*time elif iord==1: ## first derivative A = 10.0461 else: ## second derivative A = 0.0 return A ## returns function based on iord input
- In the Project Browser, click on the Motion_Crank motion.
In the Motions panel, check the User-defined
properties box.
Click on the User-Defined tab.
Note: Since the function was defined in the Python script, the USER() text field does not need to be modified.
- Check the Use local file and function name box.
- From the Function Type drop-down menu, click Python.
Use the to open the
mot_nonlin_py file.
Use DMPSUB to Add Custom Flexbody Damping
In this step you will add custom flexbody damping with the DMPSUB usersub.
Define the DMPSUB function with
“def DMPSUB():”
, and give it these inputs:“id, time, par, npar, freq, nmode, h”
Define a list the length of
“nmode”
using“cratios = nmode*[0.0]”
.“nmode”
is the number of modes in the flexbody. -
Create an
“if”
statement to iterate along the list of modes in the flexbody. The“range()”
function can be used here, resulting in“for I in range(nmode):”
In each iteration of the loop, set each index in your variable equal to 1 by
adding
“cratios[i] = 1.0”
At the end of your script, return the list variable with
“return cratios”
Save your script as dmp_nonlin.py.
def DMPSUB(id, time, par, npar, freq, nmode, h): cratios = nmode*[0.0] ## makes preallocated list for markers for i in range(nmode): cratios[i] = 1.0 ## sets marker damping to 1 return cratios ## returns damping values
- From the Project Browser, click the Conrod body (the flexbody in the model).
From the Properties tab, click the Modes...
button.
In the Modes dialog, select User
Function Damping from the drop-down menu. Enter
expression 'USER()' in the Usersub field.
Because you defined the damping in the dmp_nonlin.py script, you do not need to change the USER() expression.
- Click the (Run) button.
In the panel, change the End time to 5.0 and the
Print interval to 0.01.
Export the MotionSolve file, in the menu bar
click File > Export > Solver Deck.
Note: Currently there is no GUI option available to specify the DMPSUB file defining flexbody damping, therefore the dmp_nonlin.py must be manually added to the MotionSolve file (*.xml) by adding these statements:
Your flexbody definition should look like the following example:is_user_damp = "TRUE" usrsub_param_string = "USER()" interpreter = "Python" script_name = "dmp_nonlin.py" usrsub_fnc_name = "DMPSUB"
<Body_Flexible id = "30104" lprf_id = "30104002" mass = "7.424574879203591E-02" inertia_xx = "1.471824534365642E+02" inertia_yy = "4.505004745855096E+00" inertia_zz = "1.501914135052064E+02" inertia_xy = "-5.546373592613223E-03" inertia_yz = "-1.984540442733755E-03" inertia_xz = "1.557626595859531E-03" cm_x = "1.191728011928773E-03" cm_y = "-2.225471002399553E+01" cm_z = "5.469513396916666E-05" h3d_file = "conrod.h3d" is_user_damp = "TRUE" usrsub_param_string = "USER()" interpreter = "Python" script_name = "dmp_nonlin.py" usrsub_fnc_name = "DMPSUB" flexdata_id = "30104" animation_scale = "1." />
