MATRIX_READ
ModelingInputs a user-defined marker element.
Use
<Reference_Matrix
     id                  = "301001"
     usrsub_param_string = "USER(502,300,100,20,10,1)"
     usrsub_dll_name     = "NULL"
     usrsub_fnc_name     = "MATRIX_READ"
Fortran Calling Syntax
SUBROUTINE MATRIX_READ (ID, PAR, NPAR, ERRFLG)
C/C++ Calling Syntax
void  STDCALL  MATRIX_READ (int *id, double *par, int *npar, int *errflg)
Python Calling Syntax
def MATRIX_READ(id, par, npar):
    return errflg
MATLAB Calling Syntax
function eflg = MATRIX_READ(id, par, npar)
Attributes
ID
[integer]
The matrix element identifier.
PAR
[double precision]
An array that contains the constant arguments from the list provided in the user-defined statement.
NPAR
[integer]
The number of entries in the PAR array.
ERRFLAG
[integer]
The initialization flag.
def MARKER_READ(id, par, npar):
    eflg = 0
    errflg = 0
    r = 3 *[0.0]
    angle = 6*[0.0]
    angle_type = int(par[0])
    r[0] = par[1]
    r[1] = par[2]
    r[2] = par[3]
    if angle_type==0: # DCMTX
        angle[0] = par[4]
        angle[1] = par[5]
        angle[2] = par[6]
        angle[3] = par[7]
        angle[4] = par[8]
        angle[5] = par[9]
    elif (angle_type == 1) | (angle_type == 2):# Euler angles (313 or YPR)
        angle[0] = par[4]
        angle[1] = par[5]
        angle[2] = par[6]
    elif angle_type == 3: # Euler parameters
        angle[0] = par[4]
        angle[1] = par[5]
        angle[2] = par[6]
        angle[3] = par[7]
    else:
        errflg = 1;
        return errflg
    eflg = py_put_marker(id, r, angle_type, angle)
    return errflg
  1. MATRIX_READ can only be defined in a Reference_Matrix element. The ID of the Reference_Matrix, defined with MATRIX_READ, may be referenced as the matrix_id in the Reference_ParamCurve element. For example:
    <Reference_ParamCurve
         id                 = "301001"
         is_u_closed         = "TRUE"
         is_curve_points     = "TRUE"
         matrix_id           = "301001"
