COUSUB/COUXX/COUXX2
ModelingUsed to specify a user coupler element.
Definition
Coupler constraints are used to constrain the relative translational and/or the rotational motion of two or three joints. By using a subroutine-based formulation, for example, you can specify a variable coupler ratio based on system states, relational operators, and logical expressions. A typical example is a nonlinear coupler multiplier ratio defined as a function of an input joint velocity.
Use
User-defined coupler entity example:
<Constraint_UserConstr
id = id ...
usrsub_param_string = "USER(r1,… r30)"
usrsub_dll_name = "NULL">
</Constraint_UserConstr>
SUBROUTINE COUSUB (ID, TIME, PAR, NPAR, DISP, NDISP, IFLAG, PHI)
SUBROUTINE COUXX (ID, TIME, PAR, NPAR, DISP, NDISP, IFLAG, DFDA)
SUBROUTINE COUXX2 (ID, TIME, PAR, NPAR, DISP, NDISP, IFLAG, D2FDA2)
void STDCALL COUSUB (int *id, double *time, double *par, int *npar, double *disp, int *ndisp, int *iflag, double *phi)
void STDCALL COUXX (int *id, double *time, double *par, int *npar, double *disp, int *ndisp, int *iflag, double *DFDA)
void STDCALL COUXX2 (int *id, double *time, double *par, int *npar, double *disp, int *ndisp, int *iflag, double *D2FDA2)
def COUSUB(id, time, par, npar, disp, ndisp, iflag):
return phi
def COUXX(id, time, par, npar, disp, ndisp, iflag):
return dfda
def COUXX2(id, time, par, npar, disp, ndisp, iflag):
return dfda2
function phi = COUSUB(id, time, par, npar, disp1, ndisp, iflag)
function dfda = COUSUBXX(id, time, par, npar, disp1, ndisp, iflag)
function d2fda2 = COUSUBXX2(id, time, par, npar, disp1, ndisp, iflag)
Attributes
- ID
- [integer]
- TIME
- [double precision]
- PAR
- NPAR
- [integer]
- DISP
- NDISP
- [integer]
- IFLAG
- [logical]
Output
- PHI
- DFDA
- D2FDA2
phi = disp[0]+par[0]*disp[1]
return phi
dfda =2*[0]
dfda[0] =1.0dfda[1] = par[0]
return dfda
d2fda2 = 2*[0]
return d2fda2
