HyperBeam Results Pane
Whenever HyperBeam computes the section properties of the current section, it displays them in the Results pane.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
Supported 1D elements.
Use the Beam Sections tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
Beamsection collectors collect and organize beamsections and are used in HyperBeam to organize 1D beam section data.
Beamsection entities store 1D beam cross-section data.
The Section Browser presents a hierarchical view of all of the beamsections and beamsection collectors in your database.
Access additional tools from the HyperBeam View toolbar.
The graphics area displays a representation of the geometric layout of the section.
Types of HyperBeam sections that can be defined.
The beam cross section is always defined in a y,z plane.
Overview of how to import and export HyperBeam comments.
Create 1D mesh, align, orient, and offset elements, and release degrees of freedom.
Use the 1D Mesh: Review tool to plot area moments of inertia and stiffness.
Use the Section Property tool to update properties assigned to bar2 or rod elements (target) using a cross section on various entities as the source.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
