A Design Space library is an automotive focused library that can be used to rapidly
create full vehicle architecture concept models.
The library consists of basic primitives that can be positioned and edited to
generate the appropriate design space.
From the Assembly ribbon, click the satellite icon
that appears when you hover over the Parts tool.
The Part Browser opens.
In the Part Browser, right-click and select from the context menu.
The Libraries dialog opens.
Register and connect to a new library.
Click
to register a new library.
In the Library template field, select
DesignSpace.
In the Library path field, enter the desired library path.
In the Library name field, enter a name for the library.
Click Add.
Click Connect.
Open the contents of the library.
From the Home tools, Files tool
group, click the Open Model tool.
In the Open File dialog, navigate your design
space library and open the DesignSpace.hm
file.
The DesignSpace.hm file contains the file
hierarchy library structure.
Load primitives from the DesignSpace.hm file.
In the Part Browser, right-click on the part(s) to
load and select from the context menu.
In the Change Representation dialog, select
DesignSpace.
Click OK.
