Use the Extend Lines tool to make an existing line longer, following the general vector and/or curvature of the input
line. You can specify the distance as a numeric value, or extend the line to a specified node, line, surface, or point.
A surface represents the geometry associated with a physical part. A surface is a two-dimensional geometric entity that
may be used in automatic mesh generation.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in
automatic tetra and solid meshing.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying
mathematical definition, specified when it was created.
vector and/or curvature of the input line. You can specify the distance as a numeric value,
From the Geometry ribbon, Lines
tool group, click the Combine/Extend Lines tool.
Select Extend from the guide bar
drop-down.
Select lines to extend.
Extend in the following ways:
Drag the manipulator or enter a distance in the microdialog.
If the Follow
curvature option is selected, the extended line follows
the input line curvature. If left unchecked, a straight-line extension
is created.
Activate the Choose target checkbox to extend the
line to a target point, node, line, or surface.
Specify the range that the extended line must fall within to connect
to the target geometry using capture radius microdialog. If the end of the extended line is
within the capture radius of the target geometry, then the coordinates
are mapped to the target geometry.
