Create Entities
Add entities to the model.
- Right-click in empty space in a browser and select from the context menu.
- Right-click on a parent level entity folder in a browser and select Create from the context menu.
- Set an entity selector to the desired type, then
right-click in the modeling window and select
Create <entity> from the context menu.Note: Not available for all entity types.
(HyperMesh only)
- Select a tool used to create entities on a ribbon.
