Quickly find and open the tools, panels, and browsers that are available from the ribbons or from the Utility
Browser, as well as create entities and solver cards.
Create and Edit Assigned Entities
Create, edit, and assign new entities to an existing entity or group of entities in the Entity Editor.
Create and Edit Parameters In the LS-DYNA, OptiStruct, and Radioss user profiles, certain entities can be defined with parameters in the Entity Editor.
