This realization creates rows of HEXA elements for the body. The HEXA elements project
and connect to the adjoining shell/solid elements by touching them.
Note: Uses the
default parameters, material thickness lookup table, and material strength lookup
table from the weld_config.ini config file to set the default
attributes for the created MATL100 material.
The adhesive - shell gap exists in exactly the same configuration with the following
additional names:
HC glue mastic sealer
HC glue spot sealer
HC glue glass adhesive
This is in order to keep the realization names from HyperCrash.
The realization uses the prop_dyna_matnum_seamarea.tcl post
script. Figure 1.
