Read .h3d Node Positions
For every task, with the exception of creating a table, once the solver run is finished you will import the new node positions, and in the stitching the new connectivity, from the .h3d file generated.
- From the Airbag Solutions ribbon, click the satellite icon that appears when you hover over the tool.
- Enter a File name (.h3d file) and click Open.
