Results Processing Tools in HyperMesh
Seamlessly process solver native results in HyperMesh.
First, import result files.
Topology, connectivity, and systems are taken from the HyperMesh model.
Once the result entity is generated, it can be seen in the Model Browser. Right-click and select Show Files to display the native files used as the source by the results entity.
You can also generate new derived load cases in the form of Linear Super-Position or Envelope, with a metric definition in the case of envelope.
Once the result entity is created in HyperMesh, it will be stored as a pointer to result files.
