Model Library
The Model library contains functions that deal with model data and how values can be manipulated or transformed through model entity relationships.
The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperView.
The output parameters section of the Expression Builder allows you to define the data type label and output for the newly created result.
The list of available operators is controlled by the template file selected when loading a model and result, and it can be modified by adding or removing <using /> statements in the template.
Once an operator is selected, tables must be selected to form the input.
When an argument is passed as a constant, it is converted to a constant value table by the Expression Builder.
Additional resources can be attached to the analysis for the purpose of adding new tables.
The Expression Builder uses a Templex-like syntax to author Result Math XML commands.
A result manipulation library that enables user-defined data types to be added to a result, and transitions complex data manipulation tasks from HyperView to a reusable, modifiable set of libraries that focus solely on result processing tasks.
Various Result Math templates are available whenever a model/result pair is loaded into HyperView.
Result Math operators are contained within a set of related functions organized by category or industry vertical known as libraries.
The Math library contains operators which are used for performing basic math functions to manipulate value tables.
The Composites library contains operators that calculate multiple composite failure theories.
The NVH library contains operators which are used for frequency domain and acoustics functions.
The Model library contains geometry operators which enable visualization of element, material, and property data as scalars and vectors.
The Model library contains transformation operators which enable the conversion of directional values from one coordinate frame to another.
Binding change operators enable conversion of values from one entity to another related entity.
Utility operators are available in the Model library.
The Plug-in library provides support for applying a compiled or interpreted script operation on a value table.
The Spatial (Beta) library contains functions that deal with minimum distance and result mapping.
Operators accept string and table input/output arguments.
Constant value tables are created from the Constant operator in the Math library.
The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
Create your own user defined coordinate systems or select result coordinate systems.
Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
HyperView offers CFD post-processing capabilities for a large class of industrial applications.
Use the Tracking tool to track any entity during animation.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
