Systems
Create your own user defined coordinate systems or select result coordinate systems.
The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperView.
The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
The User Defined System dialog allows you to define your own coordinate systems and use them for post processing results.
In the topics/panels/contour_panel_r.html, topics/panels/iso_panel_r.html Value, topics/panels/tensor_panel_r.html Plot, topics/panels/vector_panel_r.html Plot, and topics/panels/deformed_panel_r.html panels, you can select the result coordinate system to be used to process results.
For shell (or planar) elements, results in any 3D coordinate system can be projected onto the element plane.
Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
HyperView offers CFD post-processing capabilities for a large class of industrial applications.
Use the Tracking tool to track any entity during animation.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
