Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
Use the Result on Stack tool to display layer based shell results along with the real
stacking sequence of the selected element(s).
As the proper information of the stacking sequence of the
element is in the FE deck, you have to load the model (deck) in a HyperMesh client in the same session, so that the tool can access the
required information in the database.
Next, you have to contour the needed result in a
contour plot and then you can run the application.
Two options are available:
Quick Query
Append Multiple Results
Quick Query
With Quick Query, you can select one element only and will get a HyperGraph pop-up window showing the needed results. Figure 1. Figure 2.
With the option Append Multiple Results, you can select multiple elements and the tool will
append to the current session as many HyperGraph pages for as
many selected entities. Figure 3.
Will display: Figure 4. Figure 5.
The Result On Stack tool support the following solver profiles:
