The Aerospace menu provides you with access to various aerospace tools.
The NVH menu provides you with access to various NVH utilities.
Use the Safety ribbon to access crash and safety post-processing tools.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
| Option | Description |
| Composite |
| Report |
| Sets | Sync HV-HM |
| Systems | Sync HV-HM |
| FBD |
| Matrix Browser |
