poIRenderOptions SetFeatureAngle
Sets the feature or crease angle between elements.
poIRenderOptions_handle SetFeatureAngle degrees
HyperView Tcl Modify
This command sets the feature or crease angle between elements.
- degrees
- Set to a value between 0 and 80. The default is 30.Note: If the angle exceeds that value, a feature line is generated.
Returns 0 if successful, otherwise an error code.
