poIRenderOptions SetErosionDrawEnabled
Sets the erosion draw enabled status.
poIRenderOptions_handle SetErosionDrawEnabled value
HyperView Tcl Modify
This command sets the erosion draw enabled status.
- value
- True/false.
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
myPostName GetRenderOptionsHandle myROptionsName
myROptionsName SetErosionDrawEnabled false
Error
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
