poIRenderOptions GetViewCubeRotatorIncrement
Gets the rotator increment angle of the view cube.
poIRenderOptions_handle GetViewCubeRotatorIncrement
HyperView Tcl Query
This command retrieves the view cube rotator increment angle in degrees.
Only valid when using HyperWorks. If HyperWorks is not being used, 0.0 is returned.
