poIRenderOptions GetViewCubePosition
Gets the current position of the view cube.
poIRenderOptions_handle GetViewCubePosition
HyperView Tcl Query
This command retrieves the view cube position, either "Lower Left", "Lower Right", "Upper Left" or "Upper Right".
Only valid when using HyperWorks. If HyperWorks is not being used, an empty string is returned.
