mdlIModelClient ImportFile
Imports the model from the file specified.
mdlIModelClient_Handle ImportFile filename
MotionView Tcl Modify
This command imports the model from the file specified.
- filename
- The name of the file from which the model is to be imported. The valid file type is ADAMS.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl CreateModel "Slider_crank.mdl"
mcl SetSolverMode ADAMS
mcl SetImportOption reader "ADAMS"
mcl ExportModel "Slider_crank.adm"
mcl CreateBlankModel;
mcl ImportModel "Slider_crank.adm";
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
None.
