mdlIModelClient GetObjectPickExceptionList
Gets the list of objects that are an exception in the pick context list.
mdlIModelClient_handle GetObjectPickExceptionList
MotionView Tcl Query
This command retrieves the list of objects that are an exception to objects in the pick context. These can be set using the SetObjectPickExceptionList command.
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl GetRootObjectHandle mo
mo InterpretEntity en Point p_0 "\"Point 0\""
en ReleaseHandle;
mcl GetObjectPickExceptionList
mcl SetObjectPickExceptionList p_0
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
Returns the objects in an exception list. If there is an error, an error code will be returned.
