mdlIModelClient GetCurWizSettingProfile
Retrieves your setting (profile) regarding where the wizard paths are specified.
mdlIModelClient_Handle GetCurWizSettingProfile
MotionView Tcl Query
- USER
- The wizard paths are specified by you in the Model Set Wizard Paths dialog.
- PREF
- The wizard paths are specified from within the preference file.
set temp 0;
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
set temp [mcl GetCurWizSettingProfile]
if {$temp == "USER" } {
puts "wizard paths are specified by the user in the Model >> Set Wizard Paths… dialog"
} else {
puts " wizard paths are specified from within the preference file"
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
None.
