mdlIModelClient CheckModel
Checks the model and assigns IDs to the model.
mdlIModelClient_handle CheckModel
MotionView Tcl Query
This command checks the model and assigns IDs to the model.
Copy the file slider_crank.mdl into the present working directory.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl CreateModel "slider_crank.mdl" mdl
mcl CheckModel
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
Returns 1 if errors are detected in the model, otherwise 0.
