HV-3099: Create Derived Results
Learn how to create derived results.
- Create and contour a new scalar result
- Create and contour a new tensor result type
- Create a new result type which is locked to a particular Load Case
- Click the Derived Results button
on the Result toolbar.
OR
- Select from the menu bar.
The Derived Results Expression Builder allows you to perform math operations on the scalar and tensor results types that are available in the result file. See the Expression Builder topic for additional information.
