HV-3090: Create Envelope Loadsteps
Learn how to create an envelope loadstep from existing loadsteps and contour an envelope loadstep.
- Right-click in the Results Browser and select .
OR
- Click the Derived Load Cases button
on the Result toolbar and set the Type to Envelope.
OR
- Select Type to Envelope. from the menu bar and set the
This utility allows you to create envelope loadsteps using existing loadsteps and their simulation steps. Envelope loadsteps are saved to the session file. Using this utility, you can also create derived loadstepsand linear superposition loadsteps. See the Derived Load Cases topic for additional information.
