Single Cable Shield
This option defines a cable shield with a single layer.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_sh7.png)
Figure 1. The SH - Cable shield dialog, set to a single layer.
Parameters:
- Shield label
- The name of the shield.
- Number of layers
- The total number of layers.
- Material label
- The label of the dielectric (as defined in the DI card) to be used as the coating for the cable.
- Thickness of layer
- Define the thickness of the dielectric coating.
- Shield definition label (Zt + Zs)
- The shield layer (SD card) to be used for the impedance part of layer 1.
- Shield definition label (Yt)
- The shield layer (SD card) to be used for the admittance part of layer 1.
