Example of AP Card Usage
An example of a typical AP usage is given.
Consider an open ended X-band waveguide radiating through a hole in a large ground plane as depicted in the figure. Away from the aperture the Z=0 plane is perfectly conducting (the tangential electric field is zero) while the magnetic field is not. Therefore electric symmetry is applied.
Figure 1. Example of an open waveguide as an implementation of the AP card.
For this example the field is considered to be purely y directed (it has only a , or , component). The field is assumed to be constant in the y direction and to have a cosine distribution in the x direction (the axis).
0.0 0.0 0.0 0.0
0.0 0.0 0.707 0.0
0.0 0.0 1.0 0.0
0.0 0.0 0.707 0.0
0.0 0.0 0.0 0.0
0.0 0.0 0.0 0.0
0.0 0.0 0.707 0.0
0.0 0.0 1.0 0.0
0.0 0.0 0.707 0.0
0.0 0.0 0.0 0.0
0.0 0.0 0.0 0.0
0.0 0.0 0.707 0.0
0.0 0.0 1.0 0.0
0.0 0.0 0.707 0.0
0.0 0.0 0.0 0.0
** Only electric fields --- use electric symmetry in the z=0 plane
SY: 1 : 0 : 0 : 2
** Define the corner points of the aperture
#wx=0.02286
#wy = 0.01016
DP: P1 : : : : : -#wx/2 : -#wy/2 : 0
DP: P2 : : : : : #wx/2 : -#wy/2 : 0
DP: P3 : : : : : -#wx/2 : #wy/2 : 0
** The geometry ends after the corner nodes have been defined
EG: 1 : 0 : 0 : : : : : : : : : : 1
** Specify the frequency
FR: 1 : 0 : : : : 9.375e9
** Specify the AP card as a new source
** The amplitude factor of 2.0 is due to the use of the equivalence principle
AP: 0 : 3 : P1 : P2 : P3 : 1 : 5 : 3 : 2.0 : 0.0 : : : : "Guide.dat"** nf_source
This will generate nine x directed magnetic dipoles of the correct magnitude in the .fek file.
AP: 0 : 7 : P1 : P2 : P3 : : 5 : 3 : 2.0 : 0.0** nf_source
: : : : : : : : 0.0 : 0.0 : 0.0 : 0.0
: : : : : : : : 0.0 : 0.0 : 0.707 : 0.0
: : : : : : : : 0.0 : 0.0 : 1.0 : 0.0
