Meshing the Mesh
Create the mesh with the correct settings.
Set a local mesh size on the faces of the waveguide ports.
- Select Union2 in the model tree.
- Expand Faces in the details tree.
Select the three waveguide faces using one of the following
workflows:
Tip:
- Press Ctrl and select all three port faces in the 3D view.
- If the face labels are known, press Ctrl and select the faces in the details tree.
From the right-click context menu select
Properties.
- On the Meshing tab select the Local mesh size check box.
In the Mesh size field, enter a value of
lambda/20.
- Click OK to close the dialog.
Create the mesh.
On the Mesh tab, in the
Meshing group, click the
Create mesh icon.
- Use the default settings ad click Mesh to mesh the model and to close the dialog.
Save the model.
Note: The CADFEKO message window will indicate that four files have been saved.
