Adding a Waveguide Source
Add a waveguide source to the first port. Use the fundamental waveguide mode.
On the Source/Load tab, in the
Sources on ports group, click the
Waveguide source icon.
In the Port
drop-down list, select Port1.
Note: All the default values are used in this example. The fundamental mode for this source will be excited (TE10). It is also possible to add multiple modes as a single source by selecting Specify modes manually.
Click Create to
create the source and to close the dialog.
Tip: Sources may also be added to ports via the model tree. Right-click Port1 in the model tree and select Waveguide source from the right-click context menu.
