Adding a Complex Load to a Port
Add a resistive load to the port of the transmission line.
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
The example considers the reflection coefficient and impedance of a microstrip patch antenna on a substrate modelled on an infinite substrate and then on a finite substrate.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
Consider the coupling between a monopole antenna and a loaded transmission line above a ground plane.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
Launch CADFEKO to get started with creating a model.
Create a monopole antenna as a single line element with a local wire radius. Zoom to extents and hide the main axes to view the full-length monopole in the 3D view.
Create a transmission line using a polyline curve with four corners. Zoom to extents to view the full model in the 3D view.
Define a perfectly conducting (PEC) infinite ground plane. An infinite ground plane is an efficient method to model a large ground plane compared to a discretised, finite sized ground plane.
Specify the frequency range of interest. For this example continuous frequency sampling is used where Feko determines automatically the frequency sampling for optimal interpolation.
Create two wire ports for the monopole and transmission line, excite the monopole with a voltage source and add a load to the transmission line.
Define a wire port on the monopole. A voltage source will be added to this port.
Define a wire port for the transmission line.
Add a voltage source to the port of the monopole.
Specify the power settings to scale the radiated power.
Create the mesh with the correct settings.
Check the model for any errors before running the Solver to ensure the model is electromagnetically validated.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Launch POSTFEKO from inside CADFEKO.
This example showed the construction, configuration and solution of an EMC coupling scenario. The model consists of a monopole antenna and transmission line on an infinite PEC ground plane. Coupling of current into the transmission line is viewed from 1 MHz to 30 MHz.
The example considers the transmission and reflection coefficients of a waveguide power divider.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
